I’ve been through the Archive and the CD and have found numerous articles on veneering and substrate preparation with one glaring omission. I have a large (3’x5.5′) desk top (the rest of the desk is fine) from which I need to remove the existing veneer.
Short of meticulously peeling it off one small piece at a time (I’ve been working on it off and on for a week.) is there any easier method. Some one once told me “Work smarter, not harder.” I’d like too!
Thank you,
Depending on the type of adhesive that was used to apply the veneer you might be able to use heat to remove it. A standard household iron will work for reversable glues like hide glue.
Matt,
Duh! ... Did you ever have a brain vacuum? As often as I have done that same thing on smaller repairs it totally went over my head for this one.
Thanks for the awakening!!!!
Francis
Update; the household iron and lots of wet rags made removal a snap.
For others wanting to try this method, make sure you have an iron with a thick sole plate. The newer low end irons have plates that are less that 1/8" and don't hold the heat very long. I've found that I can pick up old irons with 1/4" sole plates at yard sales and auctions for next to nothing. (I paid $2 for one that I am still using for dressing up popped veneer.) I burnt out two thin plate irons before finally yelled Eureka!
