I want to put a matte or very low sheen topcoat over a heavy coat of gel stain. I want it to be renewable/repairable (so, not poly). Fewer coats required is a plus. I’ve tried shellac buffed with 0000 steel wool and wax. That’s okay, but more sheen than I’d like. Compatible with unknown existing finish is also a plus. (Some of this is new wood to match old, some is antique restoration). Any suggestions? Thanks in advance.
You could buff the shellac with slightly coarser steel wool (000, eg). Or sandpaper, perhaps 600?,800? grit, to get the sheen you like.
Leave the wax off the shellac after rubbing it out.
I've not had good luck rubbing out shellac. Leaves a white-ish haze in the pores. (This is on oak.). Dark colored wax makes that disappear. What am I doing wrong with rubbing out the shellac?
Watco Satin Lacquer. Renewable. Can order from Home Depot. I have used a lot of it. Thin with lacquer thinner. Multiple coats should fill the pores.
