Does anybody have a suggestion of what kind of wood to use to replace missing boxing in a wooden plane , and a source for that wood.
really straight grained beech is fairly traditional...
Mike Wallace
Stay safe....Have fun
Planewear,
This may sound sarcastic but boxwood is the traditional boxing material used in handplanes. If you cut it so that the grain is running down and aft on the plane it will provide a better wear surface. Try googling boxwood or european boxwood and I'll bet that you will come up with a few hits.
Tom
Thanks, I will give it a try.
T. Wear
I repaired the boxing on some of my old planes with lignum vitae. I got it at a local lumber seller, and it works just fine. The old plane makers used this wood for old woodies. Boxwood is the correct replacement, but wasn't available to me when I did it. The planes I repaired are users, not for a collector's shelf, so I wasn't too worried about being 'original'.
Thanks for the suggestion, I think I will try that.
One other question, do you glue the boxing in the plane or cut it so as to have a pressure fit?
Terry Wear
tewear@yahoo.com
Mine are dovetail wedged, but I also used glue. I used poly, as I was unsure at the time how well the lignum vitae, which is very oily and hard, would glue up.
