I need lots of help and advice on repairing the surface of an old table I have. The table is structurally sound, nothing is cracked or broken. The surface of the table is really beaten up and there are a lot of scratches on the top and some on the legs. The table has been in the family for almost 100 years and has a lot of sentimental value. I want to do whatever I can to repair and restore it as much as possible. I don’t want it to look new, I want it to maintain its history of living with five rambunctious kids and many years of big family holiday dinners and celebrations.
I took it home last weekend from storage where it sat for a number of years. Looking closely at the top I think it is thin leather.
The photos show the condition of the top. I believe the gold pattern is printed on leather not wood. There is lots of crackling. I don’t know if that is in the leather or in a finish that was applied on top of the leather. The larger damaged area in photo 2 looks like the surface of the leather came off leaving some bits of bottom layer behind around the edges.
The black material on the surface in photo 5 is hard and feels like adhesive or something similar. I haven’t tried to get it off.
In addition to the top work I need to address the scratches in the wood on the top and legs.
As I go through this project I’m going to have lots of questions for you guys on how to proceed.
I’m assuming the first thing I should do is clean any dirt from the top and get that black stuff off. What materials and process should I use to do that? I don’t want to damage the gold edge accent.
Are there solvents that could help with the black residue and not cause damage?
If there is a finish on top of the leather should I try to remove that?
Two more photos.
IMO it does look like there is a coating on the leather. Start slow with the least agressive possible solvent and technique (water and a soft cloth) and very patiently ramp it up. Next maybe a mild soap. Once you have the dirt off reassess. Test with different mild cleaning products before going to solvents. You might find different places react to different approaches.
Go slooooow when you get to slovents. Alcohol on a q-tip in tiny spots would be my first "solvent". If it picks up the black stains w/o affecting the crackle you've learned something. Keep notes, maybe even a map of the top.
