I have managed to sand through the veneer on cherry plywood in a very visible spot.
Rebuilding the whole bookcase base would be expensive and time consuming.
I didn’t notice it until I had applied a coat of minwax wipe-on polyurathane. The piece is finished natural. I have tried putting a little cherry stain on the spot, but the white spots still flash too light.
If I could just darken it a little it wouldn’t show too badly. I could live with a little dark blemish, it’s natural cherry after all. I sort of like the natural color variation between, or even within, chetty boards as long as there’s not too much sapwood.
Any suggestions?
Try repairing the veneer. If you do it with care, no one will ever know it's there. I shot a video with Mario Rodriguez that demonstrates one great technique. The trick is finding a scrap of veneer to use as a patch that matches the existing grain and color.
- Matt
Video Link: http://www.taunton.com/finewoodworking/subscription/SkillsAndTechniques/SkillsAndTechniquesArticle.aspx?id=27109
Here's another article with some info:
http://www.taunton.com/finewoodworking/SkillsAndTechniques/SkillsAndTechniquesPDF.aspx?id=30019
Finally, the sidebar in this article is helpful: http://www.taunton.com/finewoodworking/SkillsAndTechniques/SkillsAndTechniquesPDF.aspx?id=24147
Thanks MattLooks like some practice is in order before I try this on my bookcase! I'm going to try it on a couple of scrap pieces and if I'm successful I'll move on to the finished piece.Thanks again
You can buy a veneer punch, which cuts an exact duplicate shape on both the bookcase and the veneer patch, but they're pricey. Practice with the chisel and see how it goes...
Thanks much
