Does anyone have any suggestions on where to get a replacement chuck key for my mortiser. The chuck is an off-brand of some sort (HD YAMA). Woodtek doesn’t have any ideas as the chuck was replaced by the previous owner.
The chuck is 13mm with a 3/8 pilot hole. Any ideas would be greatly appreciated.
Thanks!
http://www.mcmaster.com has a good selection of chuck keys. Finding the correct one will be tricky but they have a good return policy.
I had to take a chuck into the borg once to get a fitting key. No problem... then I noted the size on the inside of the machine's case. :)
