Replacement parts for Conover lathe
I use 16″ Conover lathe manufacturing in1991. But now I have to repair this.
I need front and back new bearings, seals.
How can I obtain these parts?
If I get TIMKEN parts number,I would order them from JAPAN.
I hope your good advice.
Any good bearing distributor should be able to fix you up with new bearings very easily. I've had good luck with Bearings Inc.
All they need is ID, OD and thickness, in your case taper. Or they can cross match by the Mfg. part number of your bearings.
This may be of some help. http://www.fpga-faq.org/sb-metal_hold/CD_24/ConoverOwnersManual.pdf
Pages 14 and 15
