My daughter wants her kitchen cabinet top replaced (Formica only). One area of existing Formica is loose and has a air pocket. Should I strip off the old before putting on new? Appreciate any help.Thanks, Agriffee
I would be more inclined to replace the substrate as well.
I've done quite few countertop resurface jobs and replacements as well.
To replace only the formica you would need to remove all the loose and put down something to level the surface. Once you start removing the existing you'll probably find more that is loose. You'll also find that some of the substrate will chip out in the process as well.
It would be simpler and faster to remove and replace the countertop substrate and all. you can put back either the original style or a postform type with the waterfall (rounded) front edge and attached back splash more easily than trying to get a smooth surface where there has been any damage. I only re-cover if the existing formica is tight and has no damage.
Jim
When you remove the substrate with the old formica, save some of it to use as a router table top!
Thanks for the info. I installed formica cabinets in my shop with screws in the particle board first and then covered with formica. How are cabinet tops usually attached, screws or glue or both? agriffee
Screws (the right length) :-) from underneath Mainly laminated beforehand with a scribing allowance at back and ends where installation allows it
Formica should "pop" from the substrate when heated with a clothes iron set to the high setting. Work from the edges, and place battens to keep the surfaces separated. Resurface with laminate of your liking
Robert
Thanks, that will be a lot easier. agriffee
