Can anyone recommend a 10″ table saw blade that would be good for resawing? I don’t have a bandsaw yet.
Any rip blade will do. You will be limited to 6" a most and you will be needing to take your time as this is a good way of heating up your motor and belt.
Scott C. Frankland
Scott's WOODWORKING Website
"He who has the most tools may not win the race of life but he will sure make his wife look like a good catch when she goes to move on."
You'll have less waste and an easier time doing this task if you use a thin-kerf blade, such as Freud's Diablo line; others make thin-kerf rip blades, too.
Charlie
I'll second Charlie's suggestion of a Freud Diablo blade. Their 24-tooth rip blade is available at Home Depot for an excellent price. I do have a bandsaw, but have (for some reason, can't remember) used the tablesaw to resaw a couple of times. Worked great. Be careful.
aguita,
I would recommend a rip blade with the fewest number of teeth possible/available. I have a nice Freud rip blade with 24 teeth (20 something anyway), but I wouldn't even think about using it for resawing!
If your table saw has 2 HP or less, I would definately recomment the Systimatic (SP?) 10 tooth rip blade. For thick wood or wood that's not perfectly true, it gives me great results on my old 1 1/2 HP Unisaw. Keeping less teeth in the cut gives a bit rougher finish but greatly reduces burning, binding etc.
If you can find a rip blade with very few teeth and a thin kerf, that would be even better. I have not found such a blade but I'm still looking every time I see blades displayed.
Mack
"WISH IN ONE HAND, #### IN THE OTHER AND SEE WHICH FILLS UP FIRST"
