Finally changed blades on my new (used actually) bandsaw. put on a olsen 1/2″ threw on my chintzy homemade resaw fence and comenced to resaw 7″ red oak. worked excellent made some 1/8 veneer pieces that i am glueing to a substrate now. cut quality was a little rough but planer fixed that easily. thickness was pretty consistant. its a 14″ jet with a riser block, it doesnt even have the cool blocks it just has some hardwood blocks. was pretty happy with the results.
Isn't it fun! I've never made veneer, but just making thinner boards is pretty cool, LOL. I spent some time this morning review the Timberwolf catalog prior to order some new blades to accomodate a riser kit. You might want to give their AS-S series a try the next time you need a blade to cut veneer with. Here's from the catalog:
When my spalted maple is cured out, I'm going to try one of the AS-S blades out on it!
forestgirl Another proud member of the "I Rocked With ToolDoc Club" .... :>) you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Edited 1/23/2004 6:49:26 PM ET by forestgirl
the only complaint i have is finish cut is not that smooth. but i picked up the olsen blades 4- $49, so hard to go wrong. chainsawed some black cherry today at work that i'll prolly try to slice up. i think thatll be fun.
Chainsaw implies green/wet wood. Wet wood resaws totally differently than dry wood (some even suggest a different blade). The thin wood also warps much more as it drys. So I suggest drying it at the 1 inch or so thickness before resawing.
Also, I have much better luck with smooth results with a very consistent speed of the feed. Someday I will figure out why the result seems so rough if I slow down in mid-cut, but try a very steady (slow) feed. ________________________Charlie Plesums Austin, Texashttp://www.plesums.com/wood
"the only complaint i have is finish cut is not that smooth" Not a problem I guess if the stock isn't too expensive, or you're not needing to maximize the number of boards/veneer pieces you're getting per thickness.forestgirl Another proud member of the "I Rocked With ToolDoc Club" .... :>) you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
