I tried resawing a very green 9 inch diameter log (hard maple aka sugar maple) on the bandsaw, 24 inch bandsaw, 1 inch blade, 3TPI almost new & clean blade. Blade tracks into the machine about 3/8 inch immediately then cuts very true. I have two thoughts (1) do I need to dry down the log? and/or (2) use a different blade. I am assuming I need to dry down the log. Any thoughts??
It isn't possible to dry down a whole log without cracking, stress, and rot problems, logs are always cut green but it takes a blade meant for cutting green wood to do the job properly.
I have used a green wood blade sold by Suffolk Machinery, the distributors of Timberwolf blades, and it made a big difference. Give Suffolk Machinery a call and tell them what you want to do, they'll suggest a good blade for the job.
John White
Shop Manager for FWW Magazine 1998-2006
John,Thank you very much for your thoughts and vendor information. I will follow through.L
You're welcome.John W.
You should have no problem slicing up a green log.
It's not clear to me from your description what problem you're having. Could you describe it further?
Pete
Pete,The issue relates to the blade immediately deflecting off course. After a few inches it finds the correct track and does fine. I believe the blade is properly tensioned and I know it is sharp and clean. John White suggests that a different blade could be a solution and referred me to a vendor. I do a lot of re-sawing and have never incurred this problem before.Thanks for you interest.L
