Have a unique project where I need to get a shape out of some oak and want to resaw in parallel with the grain (whereas 99% of resawing is done across the grain). IOW, the boards will ride the bandsaw table with their ends. In 25 years or so of woodworking, I’ve never done this before.
The 4 boards will each be approximately 15″ high and long.
Any particular issues or problems you know with this activity?
I have done it quite a bit, cutting out turning blocks for boxes from odd lumps of “firewood”. Just use a hook tooth blade and make sure you clear the shavings, they are longer and kind of fluffy, like a plane shaving. I have found it cuts easier than a normal cut perpendicular to the grain.
Good to know. Thanks.
Since your boards are square, why are you desiring to choose this orientation over the other?
GREG
Exo 35:30-35
Edited 5/10/2007 9:59 pm by Cincinnati
It is a 2" thick piece about 14" square (actually two of them) and I want to create an artful cupped or hourglass appearance to it. They will serve as supports for a small bench.
OK. Now I understand. When you said resawing, I only thought slicing (bookmatching, veneer, or creating two or more boards from one)Post a photo of the completed design.GREG
Exo 35:30-35<!---->
Yeah, what's the advantage?
Expert since 10 am.
35646.7
Just like Napie says- it will happen very nicely if the blade is right....
What is the shape, anyway?
35646.7
BTW, you got a good write up in Pop. Wood.
