I have several oil stone that are 30 years old and would like to restore and or clean them. One is a hard Arkansas and several other are Norton man made stones all are oil lubricant
Suggestion and comments are welcome.
Kerry,
Look in the archive. I think someone wrote once about soaking them in Kerosene and then wire brushing them. The details escape me.
Frank
*Boil them -- sounds crazy but it works.
*When my corundum oil stone surfaces became too saddled to use I flattened them out by hand grinding them against a piece of plate glass using powdered abrasives. The renewed surfaces needed no further cleaning.BJ
*I have found that if the stone is badly saddled the first step is to use a relatively smooth cement block with water to get it down to the stage where the plate glass treatment can "perfecto" it. Of course that refers to stones that someone else has "saddled".Frank
*Actually the stone are not that saddled but are glazed and dirty may be clogged. Will boiling take the clogging and reduce the glazing?Thanks
*kerry, I have boiled the stones with a little baking soda in the water, it seems to break the caking up.
*A brief scrubing together with Ajax will freshen them up. The boiling with detergents often removes all the oil (& parafin) filling the stone, and from then on, they let the honing oil go through them like a sieve. Twenty-five years ago, I switched to kerosene as a lubricant on all my stones with no clogging, and better cutting. Some very coarse stones work well with 50-50 mix of oil + kerosene to give it enough body to stay on top of the stone!John
*Hi, I,also, am in southern Maryland,near Hughesville. But in the woods. I just set up my shop and am looking for that first customer!! John
*Recently noticed that Lee Valley Tools carries the powder and thick glass if you need them, and also soft plastic sheets that are supposed to hold the powder and speed the flattening process.My experience is that arkansas stones will clog or glaze over rather quickly. Mr. Lee's sharpening bible suggests using a flattened coarse stone to level finer stones.
