I recentle put an epoxy finish on my table. The heater to my shop kicked out and it did not set properly. I didn’t realize this and consequently left blemishes where the epoxy hadn’t fully dried. Is there any way to buff this out to restore the gloss?
I've read you can use an automotive car polish (cut & polish) to remove the blemishes. You could also try wet & dry random orbital sanding - 600 - 1500 grit.
Good luck,
Richard
