Any one have any idea how to do doors like this. They slide open and sort of bread box style they go down the inside and down the back.
There are a variety of "flipper door" systems if you don't mind a bunch of hardware. Here's one.
http://www.rockler.com/product.cfm?page=34
Hi Wiskytango,
I can't quite tell from the picture or your description but maybe you're talking about tambour doors. These are traditionally made with strips of wood glued to canvas or cloth backing and operate by sliding in a groove or channel.
The photo, though, looks like the door is either vernier or very tight strips of stock. Or are the doors solid?
Paul
Yeah i think they are tambour doors. Not sure if they are solid of not, I just have a client that might want them on a peice i am working on.
Is there a source to get these pre made? Gluing a bunch of strips of wood onto canvas sounds like a bad dream
thanks
It's really not that difficult. Plus, you get the added advantage of using your own stock for good grain or color match. If that isn't so much of an issue there are suppliers that have parts and pre-made doors. These are usually only available in basic wood types.
I haven't had a call for that type of door for some time. A Google search will probably send you in the right direction. I'm heading out to the shop again after lunch and I'll look up my old source for you.
Stay tuned,
Paul
wisky ,
Depending on where in Utah you are the nearest cabinet hardware supply should carry tambour. Check on the sizes they carry and design around what is available .
Vertical tambours are slick and really not that hard to set the whole thing up. You must have a mating track on the top and the bottom .
Making the track is basically routing a groove to template with guide bushings usually . The corners can be achieved simply by running a router around the square corner of a piece of 3/4" .
You do lose some storage depth to allow the tambour to run behind any shelves.
regards dusty
From the picture they do look like tambour doors. The vertical lines and the curve where they go around the side gives that impression. The point that is missing is the grain is horizontal and the strips are vertical means it's a veneer on a substrate. It would be made of plywwod strip and is certainly doable.
There are suppliers that provide premade tambour. Many plywood suppliers carry a line of tambour products. Finding a horizontal grain type will take some extra searching.
http://www.surfacingsolution.com/Tambour.htm
And here's a FWW article that describes making veneered tambours:
http://www.taunton.com/finewoodworking/FWNPDF/011150058.pdf
I can't seem to find that suppliers name. RickL's link is a start, though. But, again, don't be afraid to try making it yourself.
Paul
