HI: This is probably old hat for many, however I wish to reverse the
direction of the motor spindles on my grinder. I vaguely remember it
has something to do with reversing the wire orientation. There are
two white wires going to a circular white something and the black wires
to the on/off switch. Any suggestions?
Thanks & cheers,
Paul
Hello Paulegan,
If I understand you correctly you are talking about a double ended bench grinder?
It does not sound like a good idea to do what you want to do because there usually is a left hand thread on the left side, and a R/H thread on the other, so that the wheels cannot loosen when starting and under load- in fact they should tighten. Reversing rotation will now tend to cancel this.
If you must do this , then you have to inter-change 2 wires from the windings in the motor, and remove the armature and flip it end for end so that the L/H thread is now on the right hand side.If the grinder has capacitor(s) then I suggest you speak to an electrician.
Why do you want to do this anyway?
P.S. What bets that somebody is going to tell you to stand on the other side???
Hi Mookaroid:
Thanks for the advice. As it turned out I simply turned
the motor 180 degrees on its base so now it is in the
desired position. It was recommended I do this for
sharpening purposes.
That's how I did it too. I have a soft cloth wheel for some sharpening tasks that obviously needs to spin that way. Peter
Paul -
I really (really) don't mean to sound rude, but if you don't understand motor wiring any more than it appears you do, I'd suggest you don't attempt doing this, at least by yourself.
Further, grinding wheels turn down and away from the user for a reason: sparks and grinding swarf aren't thrown in the user's face. Why on earth do you want the wheels to turn "backwards"?
From Beautiful Skagit Co. Wa.
Dennis
Thanks Dennis:
You are correct motor windings etc is not one of my long suits.
As it turned out I rotated the motor on the base to accomplish
getting the rotation away from me. It was recommended for sharpening
purposes.
cheers, Paul
