I’ve got an unfinished project made from red oak (I really it was white istead could have been fumed!) and I’m wondering about the best technique for producing a very dark finish.
I was thinking of using the Minwax gel stain in the Walnut color and doing a number of coats and then a UV protectant coat after my color is achieved.
Is this is best way or should I be thinking about something else? I’m been into woodworking awhile, but finishing is a whole new realm, so I really appreciate any advice.
Thanks!
I'm confused. Maybe you could go back through your question(s) and try again.
Are you dealing with raw, unfinished wood (without a finish)?
What's your reasoning for a "uv protectant" coat?
John Wooden 1910-
If you want to get a dark color the best way is to use an aniline dye. Mix a concentrated solution of the powder with distilled water. Dye won't obscure the figure, and will get what ever intensity you want. I am assuming this is not furniture that will be in outdoor sun full time. Dye fades in the sun.
But I am confused when you speak of using an UV protector. That suggests outdoor use. Red oak has problems for outdoor use. It's pores are open, end to end, so any moisture penetration can go deep and create rot from the inside out.
Would help get good advise if you can explain a bit more about the intended use.
Is there a specific reason why you need a UV barrier?
If it's indoor and out of direct sunlight I probably wouldn't worry about it, red oak isn't very UV reactive.
Transtint dyes make this color process super easy, be sure to raise the grain before applying the dye. If you don't have a need for a high durability finish (not a tabletop, for example) a couple of coats of orange shellac will bring out color nicely, then wax applied with some steel wool will take the shine off and give you a warm rich glow.
If you do need a durable finish, I'd go with lacquer instead of shellac.
Hi Corrib ,
A very dark finish may be accomplished in many ways . Go to your local pro paint supply store with some samples that are representative of your project .
There are may types of top coats you can use over the stain . I use lacquer , but always only use what is called Water White or clear non yellowing . The older formulations of lacquer had a tendency to yellow from UV rays. Even though we can stop the top coat from yellowing , there is little we can do to stop the wood from yellowing .
good luck dusty
