Ok Dave, while sharpening my sketcup skils (pardon the pun) I wanted to replicate a mortise chisel. I can create either a chisel end with no wall thickness or a non solid version in places the arches are causing me havoc with the push/pull tool. Can you assist how would I create this. I attached my drawing in scene 1 and scene 2. Any help with arches would be appreciated
Well, I was going to upload the skp file but it will not allow. (hey editors since this is a forum catagory on sketchup don’t ya think allowing a file with a scketup file format would be ok) Dave I’ll email you the skp file.
sorry that chisel is a hollow mortise chisel
Sorry I should have stated that it's a hollow chisel mortise chisel.
I got your e-mail and I'll get you an answer ASAP.
Dave
I should add that you can get some interesting effects by simply changing the shape of the cone. You might want to play with a variety of cutter shapes to see what gives you the best appearance.
thanks for the help
Thanks for the help. It is so simple when you see it in a picture. The concept of the intersection to create the geometry you want is a eurika (pardon the sp) moment for me and I'll remember that going forward. Thanks again for the quick response. U DA MAN!
Hi Bones, I'm glad that
Hi Bones,
I'm glad that worked out for you. Often it is easier to draw the shape of the cutter or the volume of space it occupies during the cut than it is to draw the cut itself. You can see a similar thing in the bolg post I did on Stopped Curved Chamfers. I used the same idea for a lot of more complex shapes when I am drawing.
The cone
The result looks pretty sharp. What grit is your SketchUp sharpening cone, Dave? ;-)
Hi Ralph, that was actually a rather coarse one but I can make them as fine as you'd like. ;)
Hope you are doing well.
Dave
Coarse and fine grits in SketchUp
"I can make them as fine as you'd like."
I was confident you could, Dave. ;-)
Thanks for the well wishes.
