I need an impact driver for removing seats in trucks (some have
slightly rusted bolts). Has anyone used the Ridgid right angle impact
driver? If so, I would like your opinion as to whether it could be a
replacement for an air ratchet wrench? Is it the only right angle
impact driver on the market?
Thanks in advance for any information you might have
Don't know if it's useful as an air ratchet, but I can tell you for sure that there are other right-angle impact drivers.
If you are looking at the battery driven unit, I think you will find it a little under powered for what you need. Might be ok if you "start" the bolts first. It also only comes with one battery (at least mine did) but it has a quick charger with it.
Starting the bolt manually would probably be acceptable if that is the only real answer. An air powered unit is a problem since we will often be away from air sources. We thought of carrying our own compresser, but a reliable power source and the potential of an extension cord giving large voltage drops is a real concern.
The Ridgid right angle impact driver has 700 in-lbs of torque or about 60 ft-lbs. That seems pretty high (not an impact hammer, of course).
got one but i don't know how good it would work for you.
get one from home depot & you have 30 days to try it out and if not happy you can get your money back same with bosch etc.
I guess the right procedure is to go out to a few of the trucks and check out what torque it takes to remove a bolt or two. That should tell me what I need to do this job! The next question will be is how accurate is the stated torque? I guess I can find that out too if removal of a bolt takes less than 60 in-lbs (the 700 in-lb rated torque of the Ridgid driver).
