I finally bought a dado blade (Freud SD208) and tried to mount a 3/4″ set on my Ridgid saw. When it wouldn’t fit on the arbor, I seemed to recall some discussions here a while back talking about the problem. I was very disappointed to say the least. I called Ridgid’s Tech Support today. They said you can leave the outside washer off when using the dado head. This will allow the last chipper to fit on the arbor for a full 3/4″ dado. I asked the obvious question: Why did Ridgid make an arbor that won’t accept a 3/4″ dado set? That’s a fairly common table saw task. Tech Support’s answer: “I don’t know”. I have not tried this yet, and wondered if any of you out there with a Ridgid saw have tried it. Tom
BTW, I also bought a new Freud regular kerf blade and was astounded at the difference from the stock blade. Wow. Rockler has all blades on sale for 20% off.
There is no harm in leaving off the washer with a thick stack of dado blades, the stack is so stiff that you don't need a washer to spread out the load.
As to why the arbor is short, it is because a longer arbor would stike the underside of the table when the blade was raised high and the blade was tilted to 45 degrees. All machine design is a compromise and this is a common trade off with table saw design.
Thanks, John. I'm feeling better about everything in life after a week of R&R. I'm going to try out the dado again tomorrow. Tom
Read the instruction manual. It clearly states to leave the outside washer off when using a full dado stack. That's what I do with mine and it works just fine.
TF
I obivoiusly missed that one when I read the manual. I'm going to give it a try tomorrow. Tom
On my Unisaw, you also have to leave off the extra washer when mounting a full dado stack. It says it in the manual, and I can tell ya it's true. So it's not just your Ridgid.
Usually I'm not cutting a 3/4" dado, so I put the washer on when there's enough thread left over for the arbor nut to seat FULLY.
