I purchased an oscillating spindle sander by Rigid today; went through setup, which was easy, and installed the 1/12 inch rubber drum and sleeve with the correct washer. The sleeve rides up in use even though I’m using extremely light pressure. It appears there is no pressure on the rubber drum to make a tight fit inside the sleeve. The nut bottoms out before making contact with the washer that sits on top of the rubber drum.
What am I doing wrong? If I’m doing nothing wrong, what’s the fix?
Thanks for any help!
You're having trouble with the 1 1/2" drum?
Second question, is the fan properly installed, it is supposed to be under the drum with the blades facing down.
Third question, is the 1 1/2" drum the same height as all of the other drums?
John White
John, thanks for replying. All the setup steps were correct; the instructions on page 16 of the manual incorrectly stated the washer to use with the drum. I spoke to "Rigid" about the error and solved the problem.
Thanks!
