Hi Folks,
I am ripping 1 inch ash on a grizzly 1023 3hp table saw with a Forest Woodworker 2 blade that is in good condition. The ash is being cut to one a quarter face framing for a entertainment center casing. Unfortunately no matter what I do I am getting
scorching so I have taken to cutting a bit more than one and a quarter and then running it through the planer. Have not worked with ash before and I was wondering if anyone had advice–is this common to ash? Should I consider getting a dedicated 24 tooth FTG blade? Thanks in advance for any thoughts or advice. Sandy
Ash has shown a tendency to burn even with a rip blade on my tablesaw. You might ask Forest about using that blade to rip ash. Were you hoping to have a finished edge after ripping? I expect to make one or two passes on the jointer after ripping to remove saw marks and any burning.
For ripping; especially for narrow, scorch prone super hard wood
. . . ( First I must say I own and like the Forest blades. I have nice Dewalt rip blades ).
Use . . .
a bandsaw
No problem even on purple heart
thick purple heart.
don't fight it.
Bandsaw.
PS: if you don't have a roller stand that adjusts high enough to use as an out feed table do what I do and try adjusting the drill press table up to the same hight as the bandsaw table. Works great. See round table in photo. I turn the table to the side of the drill press for more clearance above the work being sawn.
PPS: If you have a Laguna bandsaw with a Resaw King blade you will get cuts as smooth as a Forest table saw blade, being used to rip , and much smoother than a rip table saw blade. Can clean up with a hand plane no problem.
This might sounds silly but when was the last time you went through your tablesaw setup checklist? Over time even a perfectly adjusted saw can go out of wack...
I have had problems with Ash and Red Oak burning in the past - usually due to pitch buildup on the blade or a slightly off fence. When I don't have time to stop and figure it out I usually make a pass or two with my block plane and that solves the problem.
I clean my blades and check my setups once a month or so to keep things running smoothly.
-Ian
