Hello all,
I would appreciate any help or advise in locating a riser blocvk that would fit the above mention saw. I’ve search on google and I have found some artlcles that reference Craftsman but only a certain model. If anyone has added a riser block to a craftsman I would certainly welcome any advise they could give. Thanks Chuck from Knoxville
If it is a 14 inch Taiwanese made saw, the riser block from any other similar looking Taiwanese saw will usually fit. Ridgid makes a good riser block kit, and Grizzly is easy to order from if you can't get a local Home depot to order the riser block from Ridgid.
John W.
Thanks I appreciate it. Chuck
I own a Craftsman 14" contractor series bandsaw, model # 113.248340. Last week I bought the Jet riser kit for it. It was a perfect match up. Installed in about 15 minutes.
Craftsman 14" with riser block
Hoopa!
I just picked up this same craftsman model 113.248340 from Craigslist. The seller upgraded the spring to a cobra srping and a quick release tension lever. I want to add a riser block to the saw so I can resaw some lumber (Maple, Oak, Walnut). I know this post is several years old but thats just my point. How has the saw with the riser block held up over the years?
