There seems to be two riser blocks for 14″ bandsaws on the market. One for Delta and one for Jet. Does anyone know if one of these would fit my Harbor Freight 14″ bandsaw?
Ned
Tough question as you see how many replies you got. I am not familiar with the Harbor Frieght, but from what I've seen of the other brands; I have serious doubts. Most risers are BS specific and would require major modification to inter-change. You would have to have one present and take a close look at you BS to really see if there were possibilities.
Sorry I couldn't be specific, but that's just my guess. You might have a local machine shop have a look and see if they could produce one at a reasonable cost.
Good luck with the quest...
sarge..jt
Hop on over to http://www.forums.woodnet.net. Do an archives search. A whole buncha guys over there have the HF bandsaw and love it, after some modifications. I seem to recall some of them saying that the riser block from the Rigid at the borg will fit.
Hope this helps
Michael Prisbylla
The Home Fixer
Pittsburgh PA
Ned: the Ridgid riser block fits your HF band saw but does have to be modified to fit, a friend of mine has one and did the retrofit but noted it was a "Bear" to get it to work.. not just a drop it in and it works.. I wonder if HF has a riser kit for there saws maybe if you contact them they can help you out..
ToolDoc
