Anyone have one or does anyone know if they are a good saw.
Scott C. Frankland
“This all could have been prevented if their parents had just used birth control”
Scott C. Frankland
Sounds like the saw of which the current incarnation is the Porter-Cable 314. No first-hand experience, but I understand it has an excellent reputation. It should, considering a new one goes for over $200. Blades may be difficult to obtain, but Porter-Cable should have them.
I have one - PC model 314 - wonderful little saw. I use it to cut sheet goods to rough size then finish on my table saw. I also use it to cut 1x boards to rough length for my shop. The machine is really touted as a trim saw and I have used it on several trim jobs - works great for both crosscutting and ripping. It is small enough and powerful enough to do some tough jobs including scoring some mortises in oak timber frames.
Blades are not that difficult - I run with carbide tipped and keep a spare in the box - mine came with a real metal box. Other trim saws are not worm drive, so you won't get the torque that you have with the 314.
Seems like a good little saw.It even has the power to kick back if you try hard enough:-) The worm gives it a lot of torque.Check the depth of cut i don't think it cuts through a 2 by 4 Freud used to make blades in that size or 1/4 " bigger diameter which still fit.I used one a lot to repair clapboards .It is a lot easier than holding a No 77 over your head perched on a ladder!Our man Norm uses one to fill his hand when he puts down the router or pot of poly <G>I think Makita makes a 5 in dia which may address the 2 by 4 issue
I am looking at this saw to do just trim work. I all ready own a 7 1/4" saw that I use for framing work. I see an old Rockwell and it looks just like the PC314 and the saw is tight and in brand new shape.Scott C. Frankland
Scott's WOODWORKING Website"This all could have been prevented if their parents had just used birth control"
If the price is right go for it Be sure to check that the blade is square to the sole plate before use as the adjustments are a bit tinney.There should be no perceptable end float in the arbour.They are the tightest little saw I've used
