Rockwell Cabinet Table Saw Very Loud While Running
![](https://secure.gravatar.com/avatar/70fcecfb8c553295d5bfcbea72cbe1f9?s=52&d=https%3A%2F%2Fimages.finewoodworking.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
There is a very loud vibration or nocking while the saw is running.
Hello,
My dad has an old Rockwell cabinet table saw in his shop. It is a great saw except for the fact that it is extremely loud while it is running. It sounds like a washing machine on spin cycle with a brick in it. My dad told me that “that is what old saws sound like” after I told him that the cabinet saws in my old high school’s wood shop hummed quietly while running (they were much newer than his though). I was curious and I removed the table and examined the mechanism and found that the arbor bearings looked damaged. We had the bearings replaced and re-pressed into the arbor. Unfortunately the sound persisted after this repair. I read a good tip to run it without the belt on to see if it was a problem with the motor balance or something, when I am home next I will try that. I did notice as I was putting it back together the first time that when I spun the motor with the belt on (I pulled on the belt) I could feel a clunk or nock with every full rotation (approximately). My dad seemed to think that it was just noisy belts and getting a set of noise reducing belts would fix the noise. Im not convinced since I can hear the saw from inside the house when it is running in the basement of a garage that is separate from the house by 25ft. I will probably inherit this saw in the future and I would like to preserve this solid machine.
I dont live at home anymore so I dont have model numbers or motor specs but 2.5hp sounds familiar. I think it may be a “Unisaw”. Do any of these problems ring a bell? I would be satisfied with “that is what old saws sound like” if that is truly the case.
Thanks for any input
I haven't run a Unisaw in a long time, but these were truely classic tools. No, it should not sound like that. All the ones I ran were as smooth and quiet as any belt driven machine could be.
Diagnosing the problem in any machine is frequently a proces of elimination. Take off the belts and the motor pulley. Run just the motor. What do you hear and what do you feel? Add the motor pulley and repeat. Add the belts one at a time--Unisaws had a 3 belt drive--with and without a saw mounted and repeat. If the problem suddenly appears, you've just added the source. If the problem gradually appears, you are aggravating a problem further back.
I'd look at the motor pulley, the motor bearings, and the motor mounts in that order.
