I have a 10” Rockwell Delta Radial Arm saw. After having the motor rewound the repair service tells me it now needs a “motor relay”, but they can’t locate one. Can you help?
Is there a company that deals in parts for these older machines? Below is the information off the motor housing.
Model: M-10003
VPD 103B02W CCW
1 ½ HP 115/230 volts
1 PH 14.0/7.0 Amps
Frame: 159Y Type: SCS
Temp rise 55 C
D-705 Relay Code: G
Mfg By: Marathon Electric
Check out Ace Tool Repair at http://www.acetoolrepair.com/
You'll probably find more information on this machine at the Old Woodworking Machines site: http://www.owwm.com/
Pete
A motor repair company that can't find a relay? Sounds kind of odd. Well an obvious place to go would be Marathon as they made the original motor. Delta would be another place to check.
