Hey guys,
Would a used Rockwell contractor’s style table saw be an upgrade from my Craftsman table saw? I haven’t seen it yet, but let’s assume it’s in good shape for the sake of argument.
Hey guys,
Probably not, but look at it to be sure. Suggust you save your money until you can afford what you really want (need? naw!).
Rockwell, (aka Delta) made at least two types of contractor's saws. One was the original, heavy duty saw, sometimes labelled "Model 10" , although I think they also made a 12 inch saw as well. That would definately be a step up in quality/performance from Sears. The other Rockwell made was a bit scaled down, lighter, I think they called it "Contractor II" or something similiar, (kind of like the Mustang II, not the real thing....) that saw is probably more on a par with what you've got now.
Hope this helps,
GC
One of the best contractor saws they ever made was the 9". It doesn't have the table sag problem of the heavy duty 10". The 10" has a long basically unsupported span across the back of the table and will sag there. It's a combination of the missing structure resulting from the table insert combined with the weight and vibration of the motor and back of the trunion. I've worked with a number of the Rockwell/Delta 10" contractors saws and everyone had the sag, even an un-used new saw setting on a lumber dealer's show room floor. I fought this for years on a saw I owned and never solved the problem. Perhaps a Biesemeyer type fence with a heavy angle iron back rail could take up some of the stress; I don't know, they weren't on the market when I got rid of my Rockwell contractor's saw.
