I have the Sears-Craftsman version of a Roto-zip tool (like the kind dry-wallers use to cut out around electrical boxes). It came with a plunge router base that you simply slide the Roto-zip into and use like a router. Interestingly, the base also tilts for cutting on a bevel.
The base is a little cheap-looking, but the idea of using the Roto-zip as a router is an interesting one. Anybody ever use one of these for routing? If so, what did you use it for?
I have a Roto-zip, not a Craftsman. My collet on accepts 1/8" bits. I don't know if there is a collet replacement that will accept a router bit. Maybe some dremel bits would fit. I only use mine as a drywall cutout tool. I tried doing some wood cutting with one of their wood bits. I thought it was pretty useless, bits broke with minimum pressure, burned and were difficult to control. The guys on the TV adds must know something I don't. Drywall seems to be about all it can handle. I didn't experiment too much, didn't want to go into debt for bits.
The Roto Zip people do sell sell different bits for different materials.
But despite what you see on that infomercial, I really don't think of this thing as a high precision tool. It works great on drywall, and you should go buy a few bits, and see what it will do for you as a plunge router -- but I think you'll be disappointed.
Good luck, though.
"I would never die for my beliefs because I might be wrong."
-- Bertrand Russell
I got the 1/4" collet for my Rotozip and used it for some simple rounding over. It took a bit of practice to get the "feel" of it, but it worked just fine. I doubt if I would try it with a very elaborate profile, however.
I have a Roto-zip tool .. Not the Craftsman one.. I used it on some hard wood.. BIT BROKE and STUCK in the wall! Dang.. BE careful!
