Hi folks!
I have some nice wide maple boards 17 inches wide and i intend to use them as panels for raised panel doors and there is a line 1,5 inches wide by 12 inches long of sapwood, i mean more likely rotten dry wood that make a nice looking dark brown color curved lines in the boards.
It would be great to preserve this fragile wood in the door panels but i’m wondering how to make them solid enough to stay in the panel while cutting and routing the raise.
Any one has an advice?
There are some thin epoxies that will work for this. Here is a link.
http://www.rotdoctor.com/ You may want to work the wood close to the final size befor using it though. Without seeing how decayed your wood is, I would just be guessing at how deep it will penetrate. The worse the decay, the better the absorption, or the more solid, the harder to get penetration.
Thanks for your advice.
I wonder if that product can take an oil finish?
I intend to use an oil finish and wax polish...
Pierre
Yes I use an oil finish on most of the turnings that I do, and if I use this it will already have a saturated look, and will not take the oil, but the other or normal wood will come along and get close to the same look. The normal or non-rotten wood will not soak much of this up.Oh, I just remembered another source that has some at a much better price. This is the company, but you will have to ask for the product.
http://www.fgci.com/ If you only have a small area there are lots of turners that use cyano-acrilate or CA to get the same results very quickly. If you choose this route, be sure to read all of the precautions. Besides burning your skin, and gluing yourself to something that may be bigger than you want to wear for life, or can drag to the nearest phone.
Also the vapors will burn your eyes, and as someone has pointed out, it settles in the family jewels and can cause problems there, if you catch my drift.
Edited 6/25/2005 4:48 pm ET by rootburl
Pierre,
West Systems epoxy is fairly thin and will penetrate most rotten wood to strengthen it. I have used it many times on interior projects with good results. There is another product called Git Rot (http://www.sailnet.com/store/item.cfm?pid=26901) that is a water-thin epoxy designed to penetrate deep inside enclosed spaces. Both of these are marine products available at boating stores, as well as other sources.
Woody
Pierre
Minwax has a prodect that works pretty well... It is called High Performance Wood Hardener..
A solvent based liquid that carries a resin into the pores of the wood..
I have used it with sucess but I think I just painted over the wood.. I have no idea how it stains...
Pierre
