I would like to build a 42 inch round drop leaf table and haven’t been able to find plans anywhere. I have lots of questions about this project. 1. Do I cut the leaves before making the table round? 2. Does it make sense to cut the round table with my small Porter Cable router or would it be better to use a jigsaw and then trim with the router? 3. Since I don’t have a lathe, my base will have to be square. What would be a good design for a base? As anyone reading this post can guess, this will be (if I ever get it done) the most complex project I will have worked on. I appreciate any suggestions you might have. Shalom
Unless you can work with great precision, you should cut the leaves, mill the rule joints, and mount the hinges before you make the table round. Otherwise, small glitches conspire to make the table not have a less than smooth transition when the leaves are raised.
I would first cut with a jigsaw, and then trim with router on a circle cutting jig.
As far as plans, any Pembroke table can be converted from square or eliptical tops to round tops.
There are advantages to eliptical tops since having the somewhat shallower curve run across the front of the base makes it easier to match a front curve of the base to the curve of the front. An 18" wide table base, with the front having a round profile, the center of the bow would be roughly 2 1/4" in front of the edges. Or without a bow, say a rectangular base, 18" wide, and with the top overhanging about one inch on the sides, the center of the rail would over three inches inset from the table top.
Hello. Take steves advice, rough cut shape and fit hinges before edge moulding. book to have a look at "The technique of furniture making by Ernest Joyce"( page 381 in my copy ) several reprints. As you don't have a lathe you could go for square legs with stopped chamfers good luck and we wait the photos .regards Teabag.
