The last time I posted here, I got some great replies that helped me a lot, so I hope it happens again. In using my rounter with a jig and a centering bushing there is a difference of about 1/16 to 3/32 from one side to the other. I read in a past issue, which of course I can’t find now, that this is a common problem and that there is a solution. It seems the rounter doesn’t revolve perfectly, but wanders as it turns. Anybody remember how to deal with this or the article that told how to correct this problem? Your answers are appreciated. Creaker
You need a centering bit. It is a tapered conical looking "bit" that has no cutters. You chuck it into the router then install the apropriate guide bushing and loosen the screws securing the sub base to the router. Lower the router untill the bit hits the bushing. because the bit is tapered it will move the bushing and sub base and center it . Then tighten the screws and PRESTO it is centered.
Pardon my spelling,
Edited 12/19/2006 12:20 pm ET by mudman
