I’ve been window-shopping online for a bull nose router bit that will round over the entire edge of a 3/4″ board. Would that be a 3/4″ radius, or a 3/4″ diameter?
Different mfgs seem to have different ways of labeling the bits.
Thank you.
Thank you.
Most catalogs provide pics to illustrate the different measurements. For a roundover bit, I'd think using diameter would make the most sense. MLCS has a very clear drawing for their bull nose bits (click here).
You're right. I've been looking at the MLCS and it's explained pretty well.
Diameter, but a bullnose is not a true circle. The radius on the top edge is larger than the bottom edge.
Edited 4/21/2005 2:34 pm ET by jackplane
As you say,different manufacturers use different systems.Take LV for instance.They have bullnose bits that are half radius and bits that are full radius.This means that on a 3/4 inch board the full radius curve will start 3/8 inch from the edge and the half radius will start 15/32 inch from the edge.
http://www.leevalley.com/wood/page.aspx?c=2&p=46182&cat=1,46168
Check out the LV site,they make everything very clear.
Brent
I've been looking at LV in addition to the MLCS bits.
Some sites show the diameter as being the diameter of the entire bit (diameter of 1 1/2", for example), without indicating the diameter of the cut. Or, what's worse, they'll show a diagram with labels for various dimensions, (r = radius, e.g.) but not give measurements.
I call for universal router bit labeling standards! ;-)
Thanks.
Radius of circle for that cutter, which is 1/2 circle, = 3/8". But, in my view that would be cutting it a little close on 3/4 stock. Sample in picture link is 1/2 of 1" diameter circle on a 3/4" stick, a softer feel and look. (Note, the fence is offset for this full thickness cut.)
Routers
I go with Routerman explanation..
Diameter of the bit to me means the outside diameter of the entire bit.
