Hello,
I was cutting a groove with a 3/8″ straight bit today in some oak and the
bit slipped out of the collet. The groove was about 1/4″ deeper at one end of the cut.
It may have been something to do with the collet reducer that I needed to use.
I tried tightening the collet nut some more but it happened again anyway.
What causes this?
John
Dirt. Clean the collet and the bit. Scrape off all the glazed sawdust down to metal. Be careful not to scratch the metal.
Hello
It sounds like a problem I had a little while ago.
My problem was dirt,pitch and debry built up inside the arbor/collet.
I used simple green and a old tooth brush to really clean everything (collet, jam nut,farrel) after I dried the workings, everything worked just fine for me.
I hope your problem is as simple to solve as mine was.
one more thought.
I would also check if the router bit has any ware on the shaft as well.
good luck.
If every thing is clean as previously mentioned , and you still have the problem, that collett reducer is the culprit, especially if it is the single slit variety-these do not clamp evenly at the best of times, and also require the collett to be very tight. You should lube the load bearing faces of the nut and collett just a little to reduce friction when you tighten.
Those plain reducer sleeves are not good practice-it's far better to have the correct size collett.
And I assume the reducer you are using is a match for the bit-it is possible to mix a 6mm shank with a 1/4" sleeve/collett, which will cause grief.
And for further grief :a 12mm sleeve in a 1/2" collett.
Philip Marcou
Edited 9/27/2005 2:42 am ET by philip
I have a M12V and I had the same issue for a while when using 1/4" shafts. I read somewhere to make sure the slit on the adapter lines up with the slit on the 1/2" collett. This, with cleaning the shaft with simple green, works for me.
John- What is "simple green?- Thanks
I have the M-12v router and the collet with the single split.
I looked at in and it is caked with grime. Would oven cleaner and some
fine polishing paper work? Is there a better collet reducer design out
there that I could get?
John
Wrong guy to ask- I haven't had the problem (yet)-
It is a cleaner we bought at Lowes. It does a good job removing pitch from our blades.
It's a brand name of a general purpose cleaner. It would be with all the other cleaning supplies, not a specialty item in the tool section.
Sounds like the collet adapter, but the bit could be metric. Once in a while a metric bit can show up by mistake. This happened one time that I know of, in a shop I worked in. The cutter was new, the router was a reliable PC that never had a bit slip before. The collet was replaced and the same thing happened. We had a machine shop a block away, my boss took the bit down there after work and they measured the shank. Turns out the bit was less than 1/2". Manufacturer, don't recall whom, replaced the bit with three free ones.
mike
