I want to make a storage board for router bits. I was going to use rough sawn un-kiln dried lumber. Will that be a problem
Why? You describe un kiln dried lumber, but is it air dry or green?
If it's dry, you should be fine. If it's not, I'd be concerned with rust on the router bit shafts.
I've bored holes in a number of wood scraps to hold my bits. Wood will take on any moisture that is present. If you use wood, make the holes much larger than the shank. The steel won't be in direct contact and chances of rust will be lower. If you have large humidity swings, you may be better off using something non-porous and non-ferrous, plastic, nylon, brass or aluminum.
Bill,
When I made a storage board for my router bits I used CMT bushings from Cheyenne Tools Sales - http://www.cheyennesales.com/catalog/cmt03_51.htm They are about 20 cents each, fit snugly in a 7/8 inch hole and hold the bit nicely. I never thought about the possiblity of a moisture problem from direct contact with wood but that is an added benefit.
Good Luck, George
You don't stop laughing because you grow old. You grow old because you stop laughing. - Michael Pritchard
Edited 2/18/2007 12:02 pm ET by DustyGeorge
Why not just make the holes just slightly oversize ?
Paul :)
Lee Valley makes some bit holders that work well and are cheap/
Pedro
