Is there a router guide that has two fences that can straddle the edges of a board to enable one to route a groove down the center( 0r adjust it side to side) of the boards edge. I find that no matter how much I concentrate on holding the router square and correct with one fence bearing on the side of the board, I screw up. The thing I am looking for would have two fences that would ride on either side of a board, adjust to various thicknesses and the fences would be tall enough to keep the router square to the boards edge. I hope this description makes sense to someone. I have never seen one in a tool store or catalogue, but maybe someone has made one.
ps Yes I know you could do this with a router table, a fence and some feather boards, I am looking for something to use freehand.
Keith
Keith
I have never seen a store bought guide like that but you could make one in a few minutes.
It wouldn't be fully adjustable but how often do you need to adjust one?
Make a wood base for your router and screw two strips of wood to the bottom(of course parallel would be good) and your set.
Doug
Yes.
Pat's double-edge guide (Pat=Routerman) will give you the adjustablility. When you need to rout directly down the center, I believe you can use a base with two dowels equi-distant from the bit (perpendicular to the router's base). You spin the router as it rests on the board until both of the dowels come in contact with the board (diagonal, they'll be) and that places your bit in the center of the board's edge. Drawings for this can be seen in just about any router book.
Thank you, this is just what I was looking for. The other suggestion abot a wood base with two strips (thanks Doug) would also work, but would need several for diferent projects or to offset the grooves. Routerman has a great website. As you can probablt see, I am new to this forum and have never seen Routermans site till now. Thank you ALL.
Keith
Keith,
Using a router free hand takes a bit of concentration and if you don't do it frequently it can be nerve racking. When cutting mortices, I almost always clamp my work piece to a thick piece of stock, providing additional support for the base of the router...and sometimes attach a longish piece of wood to the router fense, ensuring perpendicular movement against the face of the work piece. Having a plunge router really helps because you can get everything in place before you start it up.
Yes, good suggestions and your observation that I may not do it that often is correct. The reason I am looking for an attachment to do it freehand is that I want to do some work on large pieces that cannot be taken apart. In other words remodelling as opposed to making new furniture.
Regards
Keith
