I’m a newbe to using a router/router table, I currently have an old Craftsman 1/4″ router and a Vermont American router table (I picked them up for a grand total of less than $35.00) what I’m wondering is what kind of improvements can I make to table fence (it’s made of plastic and is 2 piece)?
A straight stout stick, square to the table, one that won't bend, a pivot screw on one end, a clamp on the other.
Routers
Thanks for the advise.....I like it...KISS (Keep it Simple Stupid :-) )
Many of the fences sold by stores are basically a piece of aluminum angle with holes drilled in it. You can see some of the variations from simple to complicated on this site, which includes some drawings: http://www.ptreeusa.com/routertableFence.htm
You can buy aluminum at places like Metalsdepot, and it's easy to work with fairly basic tools. MDF works well for faces.
Jim
going way back, I think my first router table was a VA, and the best improvement I made with it was to toss it on the trash heap.
Not bad news, cause the router was likely worth that....
If memory serves me right, the top was actually a piece of 1/4" tempered masonite that sagged like the devil.....if that's the case you might be able to replace it with a solider piece, say 3/4" MDF or 1/2" baltic birch to avoid this....
For a fence, a trip to yer local glass fella or to a local scrap metal dealer would likely find a piece of rectangular aluminium extrusion to use for a fence. 10 bucks cash will likely give you 8' of it if you can find the right stuff....
use a hole saw to cut a big hole in the middle of it, scarf on a piece of plywood, for a face, a couple more pieces make tabs on the back to use clamps to hold it down,
Drill another hole in the back to allow you to screw on a vacuum/dust collector addapter, and stuff a couple of pieces of foam into the ends, and you got yerself a hyperstraight fence with dust collection
put a clamp on one end and slowlyswivel into the router bit and you got yerself a zero clearance dust collecting fence.
I dunno what yer budget is, but a lot of table saw mfgrs have extension tables of cast iron with router mount capabilities which to my limited knowledge run around 150 dineros.
Just my thoughts.
Eric
