I am in the process of making a router table to go in between the fence of my table saw. I have been looking at inserts to mount my router on and because of the price I want to make my own. I know someone has done this and I want to know what you used and where I can get the materials. I thought of plexi-glass but could not find any that I felt was thick enough. Any advice, thoughts or concerns would be greatly appreciated.
DIY Plate
Have you checked your local metal yard ? A chunk of 3/8 " aluminum plate would do the trick. But a lot of work.
Where are you located ?? Don't ask why yet.
Bruce,
I am in the Omaha NE area. Now you have me curious.
Insert
I have a couple of spare old Eagle America phenolic inserts and somewhere the template, used to route, the insert holes.
I upgraded to the Kreg insert.
You can have them for the Postage.
Bruce,
I found a blank from the grainger store here in town I am gonna give that a try.
Thanks, Dustin
Router Insert
Why do you need or want an insert?
Read Pat Warner's router table page
http://www.patwarner.com/router_table.html
Make your table top easily changeable so you can have a top for different bit sizes or multiple router mounts in one top.
Don
Did you mean rails?
You're talking about a router table insert to fit between the fence rails eh? I made mine out of 3/4" Baltic Birch, with read oak edging and ribs underneath. It's approx. 27" x 33" and is flush with the tablesaw top. You could design a fixture to saddle the TS fence that could then used for your router table. Just some ideas.
I used a 1/4" thick aluminum plate for the router mount. I had a machine shop bore a hole in the center of the plate for me. I also added a Router Raizer for height adjustments. So far I have been pleased with it. I'll try to attach a couple of pics.
I got my router mounted today. Bob it looks very similiar to what you did, only I found a 1/2 X 12 X 12 piece of hard plastic to mount mine with. It works great, thanks to all your suggestions maybe tomorrow I can make something besides a tool or jig.
Dustin
Dustin:
I have more than a few router tables I have made/purchased over the years.
You said.. I found a 1/2 X 12 X 12 piece of hard plastic to mount mine with. ..
Over time I would think anything except steel plate will warp a bit...
I would suggest that you consider something to reinforce the plate at the bottom. Maybe some inexpensive 'L' aluminum or steel and some Epoxy to hold the objects in place?
I am thinking about a similar idea.
I have a cheap old Craftsman table saw and I want a better router installation on the right wing extension. Right now it is just bolted up in a hole in the pan. That works but it is hard to change the setup.
I am thinking about removing the metal pan, welding up a frame from angle and bolting it into the fence extensions. Maybe adding a couple of braces down to the saw base to stiffen up the whole thing.
Then I could just drop in the actual table top for the router. An attractive option is I could also make other jigs that would drop in. This would also give me a better table top extension than the current dished pan.
If I was rich I would buy a "real" cabinet saw but that is not happening. I am thinking about setting up for a standard of 3/4" thick insert so I can use regular MDF or even plywood for some one time jig. I might use something more substantial like the metal insert for the router.
I bought the woodpecker PRL (since replaced with new and improved model) 6 + years ago and she's still going strong. Milled aluminum and great craftmanship and a chain not a rubber belt. They also sell the template for cutting the opening to fit the top. I put it in a routertabel based on norms plans. It fits the PC7518 out of the box or depending on your router sleves to fit.
http://www.woodpeck.com
