The hex set screws that control the insert height for my router table keep changing due to the vibration. It will do this In the middle of my first pass. Has anyone experienced this and if so any suggestions on how top stop this from happening?
Loctite blue. Not red!!! Blue will hold the parts from vibrating apart, but will let you loosen and tighten. The red is more permanent. You'll need a torch to take the parts apart.
Thanks I will give that a try.
The locktite will work but I found I like this system better if you have a permanent router motor setup.
https://www.amazon.com/PRS3040-Precision-Router-Insert-Levelers/dp/B000VRML54
