All,
Wold anyone recommend using 1/4″ hardboard for a router table insert? I have seen is used but wonder if it has the strength and rigidity to last.
Thanks for ou input.
Matt-
All,
Matt-
Matt,
1/4-inch hardboard is too flimsy. I prefer 1/4-inch aluminum. You can cut and drill it with woodworking tools. I've also used 1/4-inch Lexan.
Gary
The local lumberyard has plastic laminate, 1/32" thick. But I'd have to buy a whole sheet, at $45! Is there another low-friction material that could be used for inserts?
I bought 3 pieces of aluminum (12"x12"x1/4") on Ebay for about $15 total, including shipping! Cut it to shape with a fine tooth blade on my bandsaw. Cut the center hole with a hole saw using my drill press. Works great!
DW,
What are you planning to do with the 1/32-in-thick pastic laminate? I'd use it on the tabletop, but I wouldn't laminate it onto the router base insert. The insert should be stiff, like aluminum, Lexan, or polycarbonate, and it shouldn't be more than 1/4-inch thick. That's the thickness of standard, plastic, factory bases. More than that and you begin to lose depth of cut; less and you lose stiffness. You can make most any material's surface slippery with wax.
The plastic was supposed to be for a primitive router "table"--just the table top, actually--that I made last week out of 3/4" plywood. The table is functional as is, but I found three projects that use plastic laminate in router tables:
Plastic laminate glued to plywood ("Benchtop router table," WOOD, December 2001, pp 44-49)
Zero-clearance insert (http://www.woodworkingtips.com/woodtips/wbtip07.html)
MDF covered with Formica or Melamine (http://www.dewalt.com/us/articles/article.asp?Site=woodworking&ID=201)
My tablesaw requires a very thin insert, and I figured that plastic wouldn't split the way plywood does.
Janet
Edited 11/8/2002 9:08:13 PM ET by DWREAD
Matt,
I use polycarbonate, lexan, or acrylic it’s clear, rigid enough if you by 3/8” thick or better and poly is shatter proof. As far as cutting or drilling you can use regular tools, you can buy a piece of 12”x12” for about $15 dollars from any woodworking store, sign shop, or catalog. In my case I use a square piece about one inch larger than my router as my regular baseplate with holes drilled on each corner that allows me to attach to my table easily.
RickL
Edited 11/8/2002 12:49:34 PM ET by RickL
Matt
The aluminum is great. I use the phenolic and have used Lexan. Avoid the hard-board. To flimsy.
Good Luck..
sarge..jt
