I have purchased my first router. I also got a table but the table was not in original box & parts may be missing. I managed to put it together but something is not quite right. I can’t get the router bit above the table surface. Do I need to remove the subbase?
Do most router tables set up the same way?
I only paid a few bucks for it so it’s no big deal, I just wanted to try it out before I spent too much money.
Hi Dan
Is it a plunge router or fixed base router ?
Removing the subbase only add 3/8" the bit height (depth). Most plunge routers have at least 2-1/2" "plunge" capacity. Adjust the bit height (depth) and the bit will be above the table.
BOL
Masrol
Thanks Masrol
My router has both plunge & fixed bases, I used the fixed base, I will try the plunge base to see if that works better. This is my first router, It's a skil 21/4 hp. I haven't done anything with it yet, I expect I will have more questions once I get started.
Hope you don't mind
Dan
Whichever allows the most (safe) cutter projection.
Routers
Hi,
I assume you are using the Skil 1825 router. I use the same one in a router table, I mount it in the table using the Veritas Base Plate from Lee Valley (item # 05j25.01). I have used this with both the fixed and plunge bases and while I find i get greater bit projection with the fixed base, neither has any trouble getting the bit above the table. Perhaps you could post a pic of your set-up so we can see what is going on. While this router is quite good for handheld work (certainly better than most would give it credit for) I have found that it is not the best for use under the table. It is certainly usable in a table, but I have been using it like this for two years now and looking to replace it for table work.
-pjw
Hi
Yes it is a skil 1825, I'm glad you like yours. I don't have a base plate, could that be my problem? I will try to post a photo soon but right now i believe I have a problem with my camera cord. It's always something.
Thanks for your reply.Dan
Hi,
without seeing you setup, it is hard to say what exactly the problem is. One suggestion I will make is to replace the 14" collet adapter with a better quality piece ( I got a better one from Lee Valley). I found that the one that comes with the router doesn't hold bits well unless it is kept spotlessly clean ( meaning clean it EVERY time it is used), and even then there is the occasional bit slippage. But with the new adapter all is well, though to be on the safe side I make sure to buy 1/2" shank bits whenever I can.
-pjw
Dan-
You may need a collet extender. MLCS has them.
Johnny
Router Collet Extension
#9468 For 1/4" router bits.......................SALE $24.95
#9464 For 1/2" router bits.......................SALE $24.95
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/routacc1.html#router%20collet%20ext.%20anchor
Just curious, do you work for MLCS?
Edited 11/1/2007 2:09 pm ET by KiddervilleAcres
No. However, I had a similar problem and the collet extension solved it. I have one each for both 1/4" and 1/2" router bits. I think I had to buy a pair of 18mm (?) open-end wrenches for one of them. Not that easy to find those individual wrenches it turns out.
Johnny
