Router template from existing part?
I have an odd-shaped metal plate that I would like to let in to a desktop. Is there a method using router bushings and the like to create a template from the existing odd shaped part so that I can use the template to route the nicely matched recess in the desktop?
I have a dutchman insert bushing set for my router, but that creates a matched hole and plug from the same template. My plug already exists (the plate) and I need to create the template and the hole from that.
I was hoping to avoid the measure – mark – cut by hand – make several trial runs – method.
Thanks in advance.
-dch
dch,
I've used a set up like the one shown here:
http://www.jesada.com/instructions/inlay_kit.html
If you already have bushings, you may be able to piece together a similar setup with them.
david
David,
Thanks for the suggestion. I have the same type of inlay kit. This isn't quite what I was looking for because it is based on you creating a template first and then using the inlay kit to make both the cutout and the fill piece. The cutout and the fill piece will be shaped to any anomaly inherent in the template.
My situation is a bit reversed. My metal plate is the fill piece. I need to come up with a template to make the cutout to match the existing fill piece. If I make a template from scratch, any anomalies will show up as a mismatch between the cutout and the plate.
Clear as mud, right?
Have a great weekend.
-dch
How about making the negative template out of some thin, easily worked material, such as 1/4" Baltic Birch plywood or hardboard? You can fabricate it by hand, and get as close a fit to the inlay as your patience allows, even using some epoxy if necessary to build up the edge if you go a little too far.
Then use that template to rout the recess in the table top.
You would use the piece you have to make a mating (female) template then position that on the workpiece to cut the outline of the recess for the existing piece. After the ouline is cut, you switch to a large straight bit to remove the remaining material.
david
LV gives instructions that might be useful: http://www.leevalley.com/shopping/Instructions.aspx?p=40701
Jim
use your inlay kit without the ring to cut the template and then with the ring to cut the hole.
Dick
Dick, Jim,
Thanks for the suggestions and the link.
I absolutely had it in my mind that this technique wouldn't work. But after David had suggested it and I told him I didn't think it worked I started thinking it through on my drives to and from work. Being the enginerd type, I even layed it out in CAD.
And guess what... it works just as you have indicated!
Thanks again for showing me the light.
-dch
