Hey, my first post. I just had a thought, has anyone mounted their router upside down into their TS extension? I’m thinking like 3 H.P. Then fence extension for “sort of” shaper.
You've sort of reinvented the wheel with that idea. It is done fairly often and works well. You can buy commercial versions from a few different manufacturers. Welcome to Knots.
John W.
Edited 12/31/2003 9:20:49 AM ET by JohnW
This is a very common adaptation and works well, particularly if you are pressed for room. There are a number of after-market router base plate table inserts that permit easy removal of the router for hand work. You may want to also consider slotting the extension to accommodate a tract to permit the use a miter and feather boards. I would also suggest constructing a separate fence with dust collecting capability and a t-tract or slot to handle vertically-mounted feather boards.
If the budget will handle it, you might want to look into the various router lifts that make "above-the-table" adjustments extremely easy. If you haven't purchased a router yet, you might want to consider several brands that have this adjustment capability designed as part of the router mechanism.
Good luck.
Doug
