I am in the middle of a kitchen remodel, and we are installing Maple butcher block cabinets. I have basic woodworking skills, as I am an electrician by trade, but I do know my way around the wood shop. I am preparing to cut the sink (undermount) opening in my butcher block, but I am trying to find the best option for the least amount of tear out. I currently have the countertop sitting with bottom face up. I have laid out the sink on the bottom side with the template they provided, along with making my own template out of 3/4 sande plywood. I was planning on using an up cut spiral bit, with a bushing to get close to the finished size, but not sure if this is the right choice. I am wanting to save the sink cut out to make a cutting board, so I don’t want to lose size to straighten out the cuts. Hopefully this is all making sense to someone. But I guess my question is, has anyone done this? What tools did you use? What bits did you use for your router? And so on. There are quite a few questions really, I just have a wife who is my foreman when I am doing home projects, and I don’t need another lecture of why I am doing something wrong. Thank you in advance.
If the countertop is 1 1/2 inch solid maple butcher block it's going to be a bit of a slog trying to do the cutout with only the router. You will have to make multiple passes going maybe 1/8 to 1/4 deeper each time. But it should give you a nice clean opening. Use a router with dust collection or have someone follow the cut with a shop vac to keep the cut clean. Make sure you support the cutout somehow so it doesn't drop and rip a chunk out as you get close to completing the cut. Best would be to set the whole thing on a sheet of scrap ply so the cutout is fully supported.
What I generally do, though, is cut the opening roughly 1/8-1/4 undersize and then clean it up with a router using a template. I use a good jigsaw to do the rough cut. With a thick, solid top, you have to cut very slowly so the blade doesn't stray from vertical. The ideal router bit for the cleanup would be a spiral compression bit with a bearing. The compression bit gives you a clean, tearout free cut on both surfaces because of it's design.
If you are comfortable doing a plunge cut with a circular saw, that's a faster way to do the straight parts of the rough cut, finishing the corners with the jigsaw.
I did this myself about 2 years ago for my daughter. She bought 8 ft sections of 1.5 inch oak butcher block from Lumber Liquidator. So I also made a template, but used thinner stock (1/2 inch) because that gives you more clearance below the template for the bit to cut. So I used a bearing on top bit, then flipped it over and used the same size but bearing on bottom bit to finish the cut. The technique worked fine -- there was no seam from the cuts coming from different sides.
I found I had to buy a new jigsaw. I wound up getting the Festool, which is amazingly powerful and cut through the oak easily to rough out the opening. That made it a lot easier.
Did this a couple years ago in a one inch thick bar top with a 3/4 inch, double bearing trim bit.
With the compression spiral bit, there are many claims on what would be the best bit. There’s the mega flush double bearing, bottom bearing compression. What am I looking at for a cost so I know I am looking at the correct bit? The one I mentioned I saw on Infinity Cutting Tool and it’s roughly $70. Anyone heard of that bit?
Infinity makes decent bits. Their 06-693 would be a good choice. Other good brands are whiteside, amana, freud, and CMT. Don't think you'll find a decent compression bit with bearings for much less than that $70.
