I am looking for a new router. I will be using it srictly in a table as i have a smaller more poratble one for hand held use. I would like to know what would a good brand be for table use. I am partial to PC but I have also heard good things about the Triton. I am considering as a minimum a 2HP Variable speed, but am thinking it might be a little small, especially when I start using panel raising bits.
Of the big 3hp+ routers, the Milwaukee 5625 has been getting the bulk of the top ratings recently because it has above table features that the PC doesn't have. It's a well built powerful machine with VS and softstart.
The most user friendly table router I've seen is the Freud FT1700 with above table bit changes, height adjust, and height lock....it's also VS and has soft start, but it's only 2-1/4hp. I've raised panels with it, but it's not as efficient as the 5625, however the above table features are outstanding. You just have to consider how often you'll raise panels...if it's infrequent, the smaller router has some terrific features.
http://www.epinions.com/content_245903494788
http://www.epinions.com/content_228357738116
I heartily recommend the Milwaukee 5625. I previously used two plunge routers - Makita 3612 and Hitachi TR12 - in a table. The Milwaukee is far superior for these reasons:
For more information on this router and the best self-made, no sag top router table and fence go to http://www.patwarner.com.
Dear Dan,
You can't possibly go wrong with the venerable PC Speedmatic. I got by on the cheap using a 690 in my table, but depth adjustment challenges got me to relook the whole set-up. I went with the Speedmatic with variable speed and Woodpeck's Precision Router Lift. Easily adjusted height, above table bit changes, great power for handling big bits are just a few of the reasons that I settled on this combination. The initial cost was significant, but I am quite happy with the performance and am sure that it will last a lifetime and prove to be a worthwhile investment. For great prices, it is hard to beat http://www.coastaltool.com
Best,
-Tom
I mounted a Milwaukee 3 1/2 HP under the table 2 1/2 years ago. Haven't thought much about other table mount routers as there has been no need to. I'm sure there are other suitable mounts, but.......! Might consider trading it for a Clydesdale team and Bud Wagon loaded with Lite, but otherwise I can just move on to other issues.
Regards and good luck...
SARGE..
I second the comment about Coastal Tool. Their prices are good, their attitude is good, and they carry good stuff.
Edited 9/23/2006 9:45 am ET by MatthewSchenker
Dan, A lot depends on the horsepower you require but I have found that any router with a rack and pinion height adjustment mechanism is ideal for a router table.
