Routing a sloping and curved groove
Hi,
I have been racking my brain to try and figure out how to ceate a templete.
I am designing a rather elaborate carving board that will have a removable “Drippings Tray” located at the center front and underneath the tray. I would like to create a rounded 5’8″ groove around the perimeter of the carving board that starts at the center rear of the board at a 1/4″ depth and slopes down in both directions as it continues long the back, around the sides and to a center hole in the front that exits to the “Drippings Tray”. I would like the croove to be 3/4″ deep where it meets the exit hole.
I hope I have explained my problem clearly. If you have any questions, please let me know.
I sure could use some assistance with figuring out how to design a jig to guide the router.
Thank you all for any advice you could offer!
One approach would be to add spacer blocks at each end of the template that would adjust the depth of cut as you wish. (Taller block at the shallow end, shorter block at the deeper end.)
Easy One
This is easier than you think.
Let's assume the finished thickness of this thing is 1". You want the groove to vary by 1/2" from the shallow end to the deep end.
Start with a board that is 1- 1/2" thick. Mill the entire groove at 3/4" deep, with a conventional template or method.
Then block up the end you want to be shallower by 1/2" (now about 2" thick total - at one end only) or use wedges to support it at the desired angle. Send thru the planer to rermove about 1/8" or so. Reset planer thickness by another 1/8" and make another pass. Repeat as needed.
Once you have the face where you like it, remove the block/wedge on the back and turn the thing face down and plane to final thickness.
Viola!, as they say.
I dont understand.
Thanks for your advice.
What concerns me is the following:-
1. The template has to provide for going around the corners.
2. If I use a one sided template that slopes from the back side to the front, the router will not be parallel to the carving tray surface.
3. If I use a two sided template, I do not know how to construct the template to go around the corners.
Please help!
[email protected]
I missed a point
In your original description, I missed the point that you were thinking of having the grooves be high in the center, and slope to each side, as well as to the one end where the drip tray would be located.
I don't think it is necessary for the groove to be high in the center. Just lay out the grooves so they radiate from the center, and are at an angle to the centerline, similar to the branches on a Christmas tree. Using sloped (end to end) templates of, say, Masonite, that will provide a corresponding slope to the grooves.
If you are using a round nose or ball bit, it won't matter that the base of the router is not parallel to the surface, since only the radius portion of the bit will be cutting the grooves.
All of this assumes that the templates will be used with a guide bushing in the router, and that you'll actually have at least two, same-sized templates - one for the center grooves, and one or more for the perimeter groove that would connect the others near the edge of the cutting board.
http://www.eagleamerica.com/product/v130-0202/ea_-_groove_forming
http://www.eagleamerica.com/product/v130-2615/ea_-_groove_forming
Keep it simple
Hi Bruce ,
Perhaps the removable tray can sit on a slight angle enough for gravity to drain the groove ,
you won't really need much slope .
regards dusty , boxmaker
