Hi all,
One of the weakest areas of my woodworking has always been finishing. If I could not use a BLO, or shellac, or wipe on poly on the work I simply avoided the thing. The problem I always got with film finishes such as brush on varnish, poly, and lacquer was dust nibs to the point of wanting to trash the thing.
Well, recently I dug through all my old copies of FW and found an article on rubbing out a finish. I read it carefully and decided to give it a try.
I took two pieces of scrap wood about 5″ by 20″ and gave one three coats of Minwax fast drying poly and the other three coats of Pratt & Lambert #38 clear varnish. As usual, both looked like s**t. Dust nibs about one every square inch.
I let both pieces cure for a week in our bone dry Western Colorado climate and then rubbed out the poly piece first. Five minutes with 320 grit wet dry paper lubricated with soapy water, then five minutes with 600 grit wet dry lubed with soapy water for part and mineral spirits for another session, followed by 1200 grit wet dry, part soapy water, part mineral spirits just to see the difference, if any, then five minutes with FFF pumice followed by five minutes with rottenstone, both water lubed.
The results were GREAT! Never have I achieved such a fine home finishing. No blemishes, glass smooth, and super nice.
One problem. I did not get that “Baldwin Piano Read the Newspaper in the Finish ” gloss. I got instead a nice semi gloss. I can see the reflection of the florescent light overheard in the finish but not as sharply as I would like.
What did I do wrong? Is five minutes for each of these grits not enough? Rub harder? Cure longer?
I’m holding off on rubbing out the varnish sample while waiting input from this forum.
Chris
Hi Chris,
Sounds to me like you did everything right, you just didn't go far enough.
The next step would be to buff, buff, buff. To really get that count-your-nose-hairs shine, get out the rottenstone and elbow-grease again, or get a buffing-wheel and some of the more modern polishing compounds.
Constantines is a good source:
http://216.105.59.114/index.asp?PageAction=VIEWPROD&ProdID=269
But there are many others. Luthiers Merchantile sells lots of compounds used in the guitar making industry where mirror polishing is brought to a high art.
http://www.lmii.com/CartTwo/thirdproducts.asp?CategoryName=Buffing&NameProdHeader=Menzerna+Dry+Polishing+Compound
Be careful the shine don't hurt your eyes!
Best Regards,
David C
Sorry about all the edits, I had to correct spelling and links... DC
Edited 9/14/2005 8:52 am ET by DCarr10760
Edited 9/14/2005 9:03 am ET by DCarr10760
Edited 9/14/2005 9:06 am ET by DCarr10760
The process you have described is very laborious. Just like honing a plane blade, it takes more work for the next finer grit to remove the previous scratches. Each successive grit also removes part of the finish. If you have ever seen a custom auto painter block out a finish, they only make one careful stroke with abrasive paper, not a back and forth motion. If you need to use a coarse paper to remove dust nibs, you don't want to overdo it. Scratches are what make the finish satin in appearance.
There is a difference between professional finishes and those you buy off the hardware store shelf, also a difference between brands. Spraying in a controlled environment helps to eliminate many of the problems that a brush or rag applied finish causes. You don't have to start with such coarse abrasives, so, there aren't deep scratches to remove in the process.
A fairly quick way to get a great finish is to start with as fine a grit as possible and keep the sanding action to a minimum. Used paper can reduce the depth of the scratches. Remove any residue and work the surface with #0000 steel wool. This is a very fine abrasive and should be worked with the grain, not in a circular motion. I follow the steel wool with a low speed auto buffer and a polishing compound. I'm getting nice results with a terry bonnet and 3M Finesse it II. The last step is a wax, applied thinly in a linear motion and buffed, also in a straight line. I like American clear paste wax.
Everyone has their preferred methods, materials and critical eye. Surface preparation is very important. Pigmented stains can leave a surface muddy looking and BLO will continually darken and obscure the grain over time. Porous woods will need either a sanding sealer or pore filler to get the glass look. Some woods like oak, will separate at the grain and aren't worth the effort. Many pieces will look great with just the steel wool and wax. The higher the level of the finish, the more little defects will show. Perfection is very hard to achieve.
http://www.kingdomrestorations.com/catalog_g37.html?catId=5272
Chris,
I'm glad you have joined the ranks of those who realize that it is necessary to "finish the finish." Simply applying a film to the surface of wood is not enough. It must be rubbed out and the secret (if there is any) to rubbing out is to allow the film to completely dry first. This may take several weeks to a month, and the difference of just one week with certain films can make a world of difference. I would not "final rub" varnish for at least a month.
The only exception to the rubbing out process, is that very skilled finishers can apply one last thin film of spray lacquer (after the previous one has been rubbed to perfection) leaving an unblemished mirror finish. But such a final application is more likely in automotive finishes than woodworking).
While pumice and rottenstone have been the traditional methods of getting the high gloss shine, they are truly obsolete in the modern world of abrasive products. They are unpredictable and much less uniform than that which can be had at any Ace hardware or similar store. You need 3 products: automotive rubbing compound, polishing compound and swirl removal.
After getting your surface absolutely uniform with a matte scratch pattern working up through 400 grit, 600 grit and 4-0 steel wool, apply the rubbing compound, again the goal is an absolutely uniform matte appearance at that abrasive size. Then polishing compound with the same goal. You may find that either of these gives you the level of finish you want. Or go to the swirl remover. It will result in the "mirror finish" you may be after.
However, some workers find the swirl remover finished surface "too fine." You may be surprised that some finishes that you thought were "mirror bright" actually are not. Go to a piano store. Those beauties look like they have liquid glass sprayed on. But on high-quality instruments, if you look at the finish from a low angle, with the light behind the surface, you will see the fine scratch pattern applied by the finisher's loving hand at about the abrasive size of polishing compound.
Rich
Rich,
Thanks for the heads up on curing time.
OK, I know where to find rubbing compound and polishing compound but what the heck is swirl remover? Would you please name a brand and source? The local NAPA parts store maybe?
Chris
I use McGuires Swirl Remover on my black car. Works great, but I haven't tried it on furniture but will shortly.John O'Connell - JKO Handcrafted Woodworking
The more things change ...
We trained hard, but it seemed that every time we were beginning to form up into teams, we would be reorganized. I was to learn later in life that we tend to meet any new situation by reorganizing; and a wonderful method it can be for creating the illusion of progress while producing confusion, inefficiency, and demoralization.
Petronious Arbiter, 210 BC
Not a criticism but it's Meguiar's Swirl Remover. Just for those who may go looking for it. While best applied with a power buffer, it can be sucessfully applied by hand.
Go here for info: http://www.autobarn.net/meswre16oz.htmlHowie.........
Chris,
Ace Hardware, NAPA. Any place that stocks rubbing and polishing compound in the section with auto finish care products should have it. I've used various brands. Swirl Remover is simply a finer abrasive than polishing compound. I don't know the grit size, but the scratch pattern is way below the size that the eye can see, hence it gives a mirror-like finish.
But the finish really needs to be cured and needs to have the inherent hardness to benefit. Shellac and lacquer easily qualify. So do some varnishes, but they take a long time to get hard enough. The last varnish I tried it on was Varathane water borne "Crystal." It took a month until high polishing worked.
Rich
How much to rub?
I've been reading through some of the rubbing out topics and I'm not quite finding what I'm looking for. Some have been close and Rich's excellent post came closest.
My procedures are taken from are taken from Teri Masaschi's fine book "Foolproof Wood Finishing". I applied a coat of shellac, then six coats of water based Varathane Professional, gloss finish. A scuff sand between each coat and leveling sand after the fifth coat all with 320 grit. Cure for 11 days. Level with 600 grit lubed with 1:1 mineral spirits and mineral oil. All well to this point. In fact the finish is all I hoped for even at this intermediate stage. A beautiful satin finish with no shiny spots, but I'm going for high gloss. Instructions are to continue with progessively finer grits to 2000, then rotten stone. As you might guess, I'm a rank beginner for this level of finishing.
Quoting Rich "...a matte scratch pattern working up through 400 grit, 600 grit and 4-0 steel wool, apply the rubbing compound, again the goal is an absolutely uniform matte appearance at that abrasive size...."
My first problem is seeing any scratches at all. I know they are there but I can only surmise they are there by the gloss level. As I progessed through 800 and 1000 I could see no difference in the gloss. 1000 looks just like 600. I know I am removing some finish; I can see it in the slurry. It seems to me the gloss should be getting higher as I progess.
So, my real question is how much time to spend at each grit? Seems I may not be spending enough time at each but I really can't tell. Unlike leveling the indicators at progressive grits are so subtle I just can't see them.
AND you couod save some time and use Rottonstone and Oil or water...
Not sure I can post in here..
Ask the little lady to show you her favorite panties...
You take them when she is not looking.. Rub down the finish with them.. Ya be amazied what silk or Cotton 'well worm' will do!
REALLY!
Edited 9/14/2005 1:54 pm ET by WillGeorge
Well worn... I never coulds spells..
Or just a cotton 'CLEAN" cotton/nylon/rayon rag with a lub of your choice for the finish you used..
A Lube is usually not needed.. I do that and sort of like Glass..
But I don't see well at my age.. Finger touch tells you ALOT!
Edited 9/14/2005 2:00 pm ET by WillGeorge
I mostly spray precat lacquer and after about two weeks I use a card scraper to remove any dust nibs,oversprays,etc. I then go directly to pumice powder and BLO. It does not take long to get a uniform surface. The pumice must be completely removed before moving on to rottenstone and BLO. These steps give me the finish I want. For a glossier finish, substitute water for the BLO. Good Luck, Art
pumice must be completely removed before moving on to rottenstone I guess I missed a step.. I'll try the pumice first..
