All,
I just finished the cherry table in the attached photo. The finish was sand smooth, wipe lightly with mineral spirits, one coat of General Finishes Georgian Cherry stain gel that was wiped with a clean cotton cloth; and 4 coats of gloss General Finishes polyurethane lightly sanded (400 grit) and wiped with mineral spirits between each coat.
I am a newbie at finishing and this combo has worked for two other projects.
My question is this; How should I rub this finish out? I know that I have to wait a month for the poly to fully harden.
I’d like to find the perfect finish for cherry but I am sticking with the above procedure because it works for me right now. I mostly make Queen Anne cherry reproductions.
Thanks.
Bob
Very nice table Bob. Poly is a good protector for a table. Rubbing out works best with plain ol' nitrocellouse lacquer. Shines up great after a long cure. for poly, I would suggest fubbing out with 4/) steel wool and lubricant called "Wool Wax". This lube doesn't interfere with future coats either. This will give you a satin sheen. Poly never really buffs up to high gloss like lacquer. But in my opinion, poly is a better choice and protector for a table than lacquer.
I don't have any expereince with conversion lacquers, but I've read that they are as good a protector as poly and will still rub out nicely even after a short cure time.
I would do this a bit differently, since I don't fine steel wood to be as good as either sandpaper or a scraper at removing the dust nibs before rubbing to the sheen you want. Sandpaper, wet/dry, of about 600 grit will handle most of the dust nibs, alternaively you can use a cabinet scraper VERY lightly to remove the nibs. Then you can either use lubricated steel wool, or use a polishing compound. For a satin finish, I use fine grade pumice, lubricated with Parafin oil--a light mineral oil, often marketed as odorless lamp oil. For a higher gloss, you can then go to rottenstone, lubricated the same way.
Poly is harder to get to look good because it is softer than traditional resin varnishes -- alkyd or phenolic. (Softer is part of the additional toughness poly provides.) The traditional resin varnish provide plenty of protection for a table top, unless you plan to walk on it with your shoes on.
