In your video, you let the wax set up for about 15 minutes before rubbing it off. I use Antiquax (dark green-grey color) for darker woods like walnut, cherry and mahogany. What happens if you put the wax on, then rub it off just a few moments later? Am I just removing the wax as mentioned in your June article?
When using Renaissance microcrystalline wax (that I use for lighter woods), the label says it dries instantly and I rub it out right away. Would it be better if I waited longer? If I apply the microcrystalline wax with 0000 steel wool, will I contaminate the can with steel wool filings and harm the wax for later use with a cloth?
If you rub any wax out vigorously do you wipe off all of the wax and lose any benefit of the wax?
Thanks for your help.
Larry,
If you wipe the wax off immediately you take most of it off. The other reason to let it set is to let the solvent flash off, otherwise you don't get the full shine out of it.
When I apply a semi paste wax, I tend to wipe a fair amount of the excess off sooner rather than later, but I will let it set for a while before buffing it out.
The renaissance will set quickly due to the extremely thin coat that is applied. I don't think you'll contaminate it with steel wool. Just inspect it prior to using a cloth. You could always take a quick swipe with a cloth to clean the surface of the wax and then use a clean cloth to proceed with waxing. If you are worried about contamination, take some out of the can and put it into another small container and mark it as the steel wool can. This will remove any question or doubt.
You can rub a wax surface too vigorously. If you generate too much heat you just remove it while buffing. You can buff a surface to a good shine without bearing down too much on the surface. Many times I like to use a brush to do my final buffing, especially on raised or carved parts.
Peter
Thank you very much, Peter. Your answers make up a pretty complete primer on what I need to know -- and do! Thank you.
You're welcome!
Have fun.
Peter
