Seems that I always under estimate the amount of wood needed for a project. I am currently planning kitchen cabinets that will include sourcing wood from a distant supplier. Does anyone have a good rule of thumb that you would like to share?
This project includes 26LFT of base cabinets, a 5×8 island, and 30 LFT of upper cabinets of varing heights (30-48).
I am not too concerned about the boxes, as I can screw up that order and make many trips to the local supplier, but the face frames, doors and cabinets I would like to get right.
thanks – Dean
Dean
I also need to get timber in from a fair distance so I calulate amount required & add at least 25%, because not only does freight eat into the profit if you need to reorder, timber never arrives in a perfect state. If everything goes to plan & you get perfect boards with no warp or cup (remember that Murphy was a cabinet maker:-), you'll use the left over on another project.
Don
Dean,
Much of the answer depends on the type of wood and the door style ,raised panel , recessed panel , solid slabs. Some woods have a much higher waste factor then others. A general way I use to estimate footage is to calculate the square footage of the faces and add maybe 25-50% to account for waste and such depending on the particulars. Red Oak for example when purchased s3s in a FAS grade has only about 5-10% waste factor , where Alder may have 25-35% waste . Try to order a bit more so you can pick and choose somewhat , and know whats left is paid for, and like money in the bank.
hope this helps dusty
Thank you - very helpful.
So in my case I am looking at about 200sqft x 150% or about 300sqft total.
Do you find that trying to specify the width/length is of value or do you just let it go.
Dean
I just received my new wood magazine in the mail yesterday and they have an article on ordering hardwoods. In the article Steve Wall of Wall lumber recommended 50% extra. I'm not an expert, just passing along what I read, but figuring that I am not that precise and would surely have waste and a couple of screw ups, I do not see that as outrageous. It was a very good article at the end it listed several suppliers. It should be in BAM and B&N by the first of the week. You may want to go by and check it out.
